Skip to content
logo (3)
Keep Production Moving with  Automated CMM Inspection
Automated inspection that measures every part, monitors process variation, and helps keep manufacturing on track. The Mitutoyo Automation Cell transforms your CRYSTA-Apex CMM into an automated inspection solution that helps reduce operator intervention, improve measurement consistency, and support lights-out manufacturing with confidence.
The Mitutoyo Automation Cell is a modular metrology system that increases productivity through automation, data integration, and organization.
Mitutoyo Automation Cell modules can be paired for a complete metrology automation cell, or added, removed, customized and integrated into existing manufacturing systems.
Crysta7106_Co-Bot Cell_System Set.311
The 4-Module System
Expandable
Adapt the Automation Cell to different part requirements, pallet configurations, and inspection workflows. The modular design allows you to start with a standard automation solution and add options as production and quality needs grow.
Automation
The Mitutoyo Automation Cell is a flexible metrology platform designed to keep inspection moving. A palletized rack system can be preloaded with up to 16 parts, allowing the cell to automatically load, inspect, and unload each part with minimal operator intervention. Once complete, the next pallet can be loaded to keep production and inspection running efficiently.
One Stop Shop
Mitutoyo provides your complete metrology and integration needs from a single, trusted source. We streamline your entire implementation process by handling everything from initial consultation and installation to calibration and custom programming.
2103982093-02
Module 1.
Machine
High-accuracy CMM with an integrated receiver plate.
Module 2.
Part Handling
Advanced robotic arm for swift, reliable part manipulation.
Module 3.
Pallet Rack
High-density vertical storage for organized, continuous parts queuing.
Module 4. (Optional)
Workstation & Interface
Centralized, user-friendly control hub for the entire automated cycle.
Larger 2.8-inch Touchscreen
New HOME Key
Increased Efficiency
cmmrepeatable
Consistent, Repeatable Results:
Minimize operator variability and achieve highly standardized, flawless inspection consistency across every single shift.
automationcellsoftware-02
Instant, Automated Reporting:
Real-time data logging automatically exports critical quality metrics into PDF, CSV, ASCII, or AQDEF formats, feeding directly into your MeasurLink® database.
RFID
Smart RFID Integration:
Eliminate manual programming setup. Scan RFID tags to automatically select, queue, and execute the correct MCOSMOS inspection routines.
Co-Bot Cell_System Set.314 1
Hands-Free Part Handling:
Deploy high-precision robotics to manage part loading, positioning, and unloading without manual intervention.
Learn more about this Solution
