Encoders and Sensors
Mitutoyo sensor and encoder products include high-accuracy displacement sensors, linear encoders, and digital readout (DRO) systems designed to deliver repeatable, reliable measurement directly within your machines and processes. Built for seamless integration and rugged industrial environments, these solutions provide real-time feedback, tighter control, and faster troubleshooting.
Whether you’re enhancing machine motion, refining process monitoring, or embedding Mitutoyo precision into your automation for smarter workflows, Mitutoyo Sensors and encoders empower you to build more capable solutions that elevate measurement accuracy and overall quality performance.
1920×829
Quick Contact Links
Sales Support
1-888-MITUTOYO
Get pricing and availability
Technical Support
1-888-MITUTOYO
Monday-Friday 8am-5pm EST
Request Information
Get detailed product
specifications & pricing
Find Distributor
near you
OEM
Encoders
Mitutoyo DROs paired with linear scales deliver an unbeatable combination of precision, speed and ruggedness for machine tool and positioning applications. Mitutoyo linear scales are available in several different types, sizes, response speeds and IP protection ratings to meet the demands of any application. Paired with intuitive DRO displays featuring multi-axis readouts, preset macros, switchable inch/metric resolution and SPC data output, operators get real-time, repeatable feedback to help speed up set-up times, reduce manual calculation errors and improve overall machining cycle times.
Sensors
When you need in-line, non-contact measurement that won’t slow down your process, Mitutoyo SurfaceMeasure Series of line laser sensors delivers with rapid data transfer and precision wherever you need it. These smart line-laser sensors, including the wide-field SM2929S, compact high-resolution SM0303S and the versatile mid-range SM1008S, combine rugged build quality with high-speed scanning (up to 10 kHz) and integrated web-based software for immediate deployment. They in-line measurement sensors are built to handle harsh factory environments, deliver clean 2D and 3D surface profiles and dimensional data, and seamlessly support smart manufacturing workflows through embedded measurement, inspection and parts-matching tools.
Encoders
Sensors
Ask Mitutoyo
Frequently Asked Questions
How do Mitutoyo products support OEM applications?
Mitutoyo offers a wide range of components specifically for OEMs to integrate into their own equipment and systems. This includes high-precision linear encoders, sensors, and miniature microscope units. We work with OEMs to develop custom solutions that seamlessly integrate with their production lines, providing the core measurement technology they need.
What types of sensors and encoders does Mitutoyo offer?
We offer a variety of sensors and encoders designed for different applications, including:
Linear Gauges: For accurate linear displacement measurement in quality control applications.
Laser Scan Micrometers: For non-contact measurement of small or delicate parts.
Non-Contact Line-Laser Sensors: Designed for high-speed part measurement in automated systems.
Linear Encoders/Scales: Both optical and electromagnetic types for position feedback in machine tools and precision stages.
What is the difference between an optical and an electromagnetic linear encoder?
An optical linear encoder uses a glass scale with precise gratings. A light source and a light-receiving device detect changes in light intensity as the scale moves, converting this into a displacement value. An electromagnetic linear encoder uses electromagnetic induction and is highly resistant to environmental contaminants like coolant, oil, and dust, making it ideal for harsh workshop environments.
What are the benefits of using a Mitutoyo DRO system on my machine to
Mitutoyo DRO systems dramatically improve machining accuracy and efficiency by providing:
Clear, High-Resolution Display: Digital counters show the precise position of the cutting tool or workpiece, eliminating the need for manual calculations.
Zero-Setting at Any Position: You can set a zero point at any location on a workpiece, simplifying complex operations.
Versatile Functions: Many DRO counters feature one-touch macro keys and functions to simplify operations like bolt-hole circles, line holes, and angular measurements.
Can I use Mitutoyo DRO scales with a different brand of digital readout counter?
Mitutoyo scales and counters are designed to work together as a system for optimal performance and accuracy. While some cross-compatibility may be possible, it is not universally guaranteed due to differences in wiring, voltage, and signal protocols. We recommend using a complete Mitutoyo DRO package for the most reliable and accurate results.
Complete Catalog US-1006
For all your OEM needs
Training & Education
Enhanced Services
Field Service
E-Learning
Learn at your own pace! Enroll in Mitutoyo eLearning and get extensive hands-on training on our tools and software, including MCOSMOS C1 (STC-100 v5) and MCOSMOS-M1 (STC-101) courses.
Quality You Can Trust
Expert Support
ISO 17025 Accredited
Industry-Leading Warranty
NIST Traceability
