Skip to content
logo (3)
Precision Contour Measurement, Simplified
Accelerate your inspection cycles and eliminate complexity with the Mitutoyo CV-2100M4 Contracer. This high-resolution, motorized contour measuring system brings speed, accuracy, and intuitive operation together in one complete, ready-to-go package.
Take advantage of special promotional pricing effective through December 23, 2026.
Why Choose the CV-2100M4?
Higher Product Quality: Ensure flawless execution on complex part geometries like cams, gears, turbine blades, and injection molds.
Faster Production Cycles: Achieve positioning speeds up to 20mm per second and utilize a smooth up/down mechanism with fine feed control to drastically reduce setup times.Measure complex part profiles in seconds
Lower Scrap & Rework Rates: Catch out-of-spec conditions instantly, reducing material waste and administrative overhead.
Seamless Compliance: Automatically generate comprehensive, audit-ready inspection reports in PDF, CSV, or DXF formats.
CV-2100M4: Engineered for Excellence
Three Simple Steps to Error-Free Measurement
We believe advanced metrology shouldn't require a steep learning curve. The CV-2100M4 simplifies your entire measurement routine down to three clear steps:
Includes everything you need to get started: PC, monitor, software, and certified calibration artifact.
1. Simple Manual Positioning
Set up parts quickly and safely. The detector unit features a centralized, user-friendly control panel with dedicated function keys that reduce motion overhead and improve operator efficiency.
2. One-Scan Execution
Eliminate manual programming errors on the shop floor. Operators can simply scan a barcode to instantly load and run the correct part program.
3. Clear Pass/Fail Results
The system does the heavy lifting for you. After measurement, Go/No-Go tolerance judgments are displayed with unmistakable visual and audio alerts, making it easy for any operator to make fast, accurate decisions.
Ready to Experience the CV-2100M4 for Yourself?
Larger 2.8-inch Touchscreen
New HOME Key
Increased Efficiency
Powered by All-in-One FORMTRACEPAK Software
The CV-2100M4 comes equipped with powerful, intelligent analysis tools that handle system control, contour tolerancing, and report creation in a single interface.
41_1_FORMTRACEPAK_202105_p_12_en
Contour Tolerancing
The best-fit processing function that moves the coordinate values of the design data and measurement data to the optimum positions is provided as a standard feature. Since the tolerancing results can be visually displayed as graphics, tolerance values and tolerance expansions in each coordinate, or output as a text file, they can be utilized as feedback data for machining systems.
Design value generation function
You can generate design data from CAD data (DXF or IGES file) or text data. Furthermore, since you can also convert measurement data into design data, you can save parts data prior to use (testing) as design data and effectively utilize it for checking the wear following use (testing).
Integrated layout
You can use simple operations to lay out graphics obtained from measurements as well as measurement results for surface roughness, contour, and roundness on a single page. Furthermore, since the program now allows you to specify a saved file and paste it, you can easily paste results from multiple files.
41_1_FORMTRACEPAK_202105_p_10_en
Experience the CV-2100M4 today
