Skip to content
logo (3)
FALL PROMOTION 2026
Save up to 20% on many of the most popular Mitutoyo precision measurement instruments and tools from Sept 1st, 2026 through December 18th, 2026. Select products also include complimentary, installation, calibration, free training, and more!
View Promotion
FALL INTO SAVINGS
Take advantage of the 2026 Fall Promotion and unlock 5% to 20% savings on precision instruments, with select models including complimentary shipping, installation, calibration, and training. Featured products include QuantuMike Digital Micrometers, the SJ-220 Portable Surftest, ID-C/ID-F Digimatic Indicators, LH-600F Linear Height, Profile Projectors, and many more.
fallpromo2026
To explore all the special offers and pricing, download the 2026 Mitutoyo Fall Promotion brochure. This limited-time offer is the perfect occasion to upgrade your metrology equipment. Learn more about our featured products below!
For detailed information on the 2026 Mitutoyo Fall Promotion, complete the adjacent form to be contacted by phone or email.
SPOTLIGHT PRODUCTS
ML 11 INTRO
Real-Time Quality Control. Simplified.
Software is only as good as the data feeding it. MeasurLink 11 is engineered to perform at its peak when connected to Mitutoyo Small Tools and Data Management Hardware. Collect instant digital output from Calipers, Indicators, Sensors, Vision systems, and Coordinate Measuring Machines to eliminate human transcription errors and protect your SPC investment.
Support center tile view with drawings
New Licensing Model & Compatibility
MeasurLink 11 introduces a flexible licensing model designed to adapt directly to your operational structure. Deploy via a traditional fixed-node license or scale cost-effectively with a floating/concurrent license that grants seamless module access across multiple shared users without purchasing extra seats.
Database & OS Compatibility: Built for modern IT ecosystems, MeasurLink® 11 supports Windows 11 and ships directly with Microsoft® SQL Server Express Edition 2025. For enterprise architecture, it integrates with SQL Server Standard and Enterprise Editions (2019, 2022, and 2025).
Untitled-1-05-1
  • Utilizing a unique processing technology, the MDE QuantuMike features a wider thread pitch, enabling the spindle to move 2.0 mm per rotation - four-times faster than other micrometers.
  • The MDE QuantuMike has a maximum permissible error of just ±1 μm to ensure it meets the demands of high-precision workpieces.
  • An approach speed warning function helps prevent damage from excessive speed with a flashing display to alert users.
  • The calculation function automatically computes correction values for machine tools from measurement results. This eliminates the need for manual calculations to reduce human errors and help prevent processing defects.
  • Tolerance (GO/NG) icons on the LCD display for quick judgments. Upper and lower tolerance limits must be entered beforehand
  • The calibration period notification icon starts blinking at a set time before calibration is due (e.g. 1 week before the calibration date). If the deadline is exceeded, the entire screen starts blinking to notify the user.
QM email_2 1600 X 560
New MDE QuantuMike Digital Micrometers
The new Mitutoyo MDE QuantuMike delivers measurements up to 4x faster than standard micrometers while maintaining exceptional accuracy with ±1 µm permissible error. Beyond speed and accuracy, the QuantuMike features a user-friendly design with an enhanced digital display, easy-to-use function buttons, and customizable settings. Its IP65 protection rating makes it ideal for use in manufacturing environments that demand high-precision results. New Digimatic S1 output capabilities allow for measurements to be exported to spreadsheets or data management systems.
The SJ-220 Surftest is a portable, user-friendly surface roughness tester designed to be compact and easy to use with one hand, providing highly accurate results almost anywhere. The built-in battery lasts for up to 1,000 measurements without needing a charge, making the SJ-220 indispensable in the field or on the manufacturing floor.
Divider-Visual-RA-220-Software
The larger 2.8-inch color touchscreen back-lit display provides high visibility in all settings, even in dimly lit locations. The screen orientation is easy to change, and the new user interface helps make operations faster and easier. The touch screen supports flick and swipe operations as well, making it easy for anyone to perform measuring work. The SJ-220 meets a wide range of international standards, including the latest ISO 21920, and is capable of wireless data sharing and reporting with the optional U-WAVE-TIB and the free SJ-APP.
41_3_178-741-11_202311_IM-3 1 (1)-1
Key Features
• Compatible with the ISO 21920 profile surface texture standard.
• Built-in 2.8-inch color graphic backlit touchscreen delivers clear visibility and intuitive operation, even in low-light shop-floor environments.
• Flexible LCD display orientation switches seamlessly between portrait, landscape, left-handed, and right-handed viewing modes.
• High-capacity battery performs approximately 1,000 measurements on a full charge for reliable mobility.
• Optional U-WAVE-TIB Bluetooth® wireless transmitter enables bidirectional communication, remote measurement condition setup, and immediate results display.
• Dedicated SJ-APP application streamlines measurement workflows and enhances operational efficiency.
• Multilingual interface supports 25 interchangeable languages for global usability.
indicators_generic-scaled
Key Features
•  The ID-C and ID-F ranges now include models with 20μinch / 0.5 μm resolution. •  The units are also capable of resolution switching. **Except for the ID-C 0.01 mm resolution model.
•  The LCD displays an icon to notify the user when the set calibration time approaches. This facilitates the proper precision management of ID-C/ID-F.
•  The units have large screens that can display various information in an easy-to-read manner. They also have an analog bar for observing the approach to tolerance.
• The IDF Indicator Series features a backlit display that shifts from green to red when out of tolerance.
MITUTOYO IDC DIGITAL INDICATORS
Mitutoyo ID-C and ID-F Digimatic Indicators provide incredible accuracy with higher resolutions down to 20 µ inch/0.5 µ m. The larger LCD screen can display various information in an easy-to-read manner and features an analog bar for convenient observations of subtle movements such as the approach to tolerance.
THESE SPECIAL DEALS WON'T LAST FOREVER!
These special deals won’t last forever! Be sure to download the 2026 Mitutoyo Fall Promotion brochure to save on popular Mitutoyo tools and instruments including the featured products above along with data management solutions, calipers, micrometers, linear encoders, indicators, height gages, microscopes and hardness testers before December 18th, 2026, when the Fall Promotion ends!
