Upgrade to MCOSMOS v5.4:
The All-in-One Metrology Platform for Ultimate Precision
Upgrade Today to MCOSMOS v5.4 — Smarter Automation from Lab to Line
Take advantage of our latest release and elevate your inspection workflow.
Work Smarter, Measure Faster with MCOSMOS v5.4
MCOSMOS V5.4 New Features & Improved Functions
Parallel Planes
Two planes with measurement points create a median plane that can be used as a standard measured plane and as a datum.
GD&T ISO/ASME
Supports new positional tolerance functions that align with both ASME and ISO GD&T standards for standardized results and better global compatibility.
Auto Camera Switching
Auto Camera Switching selects the appropriate objective lens based on stored probe data, enabling efficient, automated measurements with multiple optical probes in one program.
Active CMM Configuration
Creates capability to select off-line or on-line without starting CMM System Manager.
Automation
Mitutoyo Connect in MCOSMOS V5.4 enables automation by allowing users to define input/output signals and set operational states within the measurement process.
Expanded Repeat Mode Options
Expanded Repeat Mode Options in MCOSMOS V.5.4 replace the drop-down menu with individual launch buttons for quicker, more intuitive access to each repeat mode.
Larger 2.8-inch Touchscreen
New HOME Key
Increased Efficiency
