The fastest, most accurate micrometer available now.
The Mitutoyo QuantuMike gives you faster measurements without sacrificing accuracy.
For detailed information on the Mitutoyo QuantuMike, complete the adjacent form to be contacted by phone or email.
Fast. Accurate. Reliable.
The Mitutoyo QuantuMike uses a unique coarse precision-ground spindle to provide accurate measurements up to four times faster than conventional micrometers. Engineered for precision, reliability, and ease of use, the QuantuMike is the ideal tool for enhancing productivity in demanding environments.
Bidirectional Digimatic S1 Communication
Seamlessly manage and configure your Digimatic gages with bidirectional serial communication. This feature allows for easy setup and monitoring of Digimatic gages directly from your PC, enabling precise and efficient management. Apply consistent settings across multiple gages simultaneously, saving time and ensuring uniformity across your operations.
User-Friendly Design
Tolerance (GO/NG) icons on the LCD display for quick judgments
Calculates the corrective value
Displays tolerance judgement mark
Upper and lower tolerance limits must be entered beforehandOperation and Calibration Features
An approach speed warning function helps prevent damage from excessive speed, with a flashing display to alert users. Calibration management is simplified with warning alerts for upcoming calibration dates, ensuring your device remains accurate and reliable.
Exceptional Accuracy
The MDE Quantumike boasts a maximum permissible error of just ±1 μm, ensuring it meets the demands of high-precision workpieces.
Durable and Reliable
With an IP65 protection rating, this micrometer is water-resistant and dust-resistant, capable of withstanding challenging environments where exposure to coolant and debris is common.
Improved Display and Interface
The display is larger and easier to read from any angle, featuring clear measurement values and icons. Larger buttons enhance usability, and key operations can be customized for a more intuitive user experience.
Enhanced Usability
The ratchet thimble mechanism ensures stable, one-handed operation, providing tactile feedback through ratcheting sounds to confirm secure measurements. The speeder ratchet aids in rapid spindle feed, improving efficiency.
Rapid Measurement with High-Speed Movement
Utilizing a unique processing technology, the MDE Quantumike features a wider thread pitch, enabling the spindle to move 2.0 mm per rotation—four times faster than typical micrometers.
Ready to Experience the QuantuMike for Yourself?
Whether it’s for aerospace, medical, automotive, or general manufacturing, equip your operations with the Mitutoyo QuantuMike for its advanced speed and accuracy. trusted reliability, and several other innovative features.
