View Our New Products
Built for What You Create
A True Partnership: Our goal is to give you the absolute certainty you need to go out and make a perfect creation.
CRYSTA-Apex® V PLUS Series CMM
The CRYSTA-Apex® V PLUS Series delivers the high-speed, multi-sensor coordinate measurement capabilities required for tight-tolerance quality control. Equipped with a real-time thermal compensation system, these machines maintain specified accuracy across a temperature range of 16°C to 26°C, making them suitable for both controlled labs and active production environment bypasses.
Volumetric Accuracy:
E₀,ₘₚₑ = (1.7 + 3L/1000) µm (model dependent, where L is measuring length in mm)
Drive Speed:
Maximum 519 mm/s with 3D acceleration up to 2,309 mm/s²
Automation Ready:
Features an integrated receiver plate for seamless robot/co-bot pallet loading interfaces.
Primary Applications
Prismatic automotive components, complex aerospace housings, multi-feature machined parts, and automated mold/die inspection.
Engineered for dedicated, non-contact cylindrical inspection, this high-speed optical system measures part diameter and Total Indicator Reading (TIR) simultaneously in a single automated pass. The integrated motorized headstock rotates the workpiece under continuous scan, eliminating the hand-tool variability common across multi-shift operations.
If your production volume is outpacing your inspection capacity, you can transform a standard CMM into an unattended workflow powerhouse. The Mitutoyo Automation Cell uses a modular, 4-module hardware layout to eliminate routine operator loading and programming steps entirely.
We’re continually upgrading our digital infrastructure to help you eliminate isolated islands of measurement data. MeasurLink® 10 connects your shop-floor hardware into a unified Statistical Process Control (SPC) network, giving your team real-time visibility into process variance.
• Real-Time Monitoring: Monitors tolerances as measurements occur, flashing instant alerts if a process trends toward a control limit.
• Hardware Compatibility: Consolidates data from CMMs, vision systems, and ABSOLUTE® digital calipers into a centralized SQL database.
• Audit Trail Security: Supports compliance frameworks with secure user-access controls and verification tracking.
Larger 2.8-inch Touchscreen
New HOME Key
Increased Efficiency
We know you aren’t looking for marketing enthusiasm; you're looking for verifiable, repeatable metrology data that validates your machining tolerances. We've built our current line of hardware around low-maintenance glass encoders, high structural rigidity, and interoperable software networks. If you're planning a facility relocation, configuring a new high-throughput production cell, or optimizing a tight-tolerance workflow, our engineers can customize sub-assemblies and custom fixtures to meet your precise footprint.
