Skip to content
logo (3)
SPRING PROMOTION 2026
Save up to 20% on many of the most popular Mitutoyo precision measurement instruments and tools from April 1st, 2026 through June 30th, 2026. Select products also include complimentary, installation, calibration, free training, and more!
View Promotion
SPRING INTO SAVINGS
Take advantage of the 2026 Spring Promotion and save up to 20% on Mitutoyo precision instruments, with select systems including complimentary installation, calibration, and training.
Featured products include QuantuMike Digital Micrometers, SJ-220 Portable Surftest, ID-C/ID-F Digimatic Indicators, LH-600F Linear Height Systems, Profile Projectors, and more. For a limited time, Mitutoyo digital calipers with SPC data output are available at the same price as models without output, giving you data-ready measurement and SPC capability at no additional cost.
Better measurement. Better data. Bigger savings.
sp26
To explore all the special offers and pricing, download the 2026 Mitutoyo Spring Promotion brochure. This limited-time offer is the perfect occasion to upgrade your metrology equipment.
For detailed information on the 2026 Mitutoyo Spring Promotion, complete the adjacent form to be contacted by phone or email.
SPOTLIGHT PRODUCTS
QM email_2 1600 X 560
New MDE QuantuMike Digital Micrometers
The new Mitutoyo MDE QuantuMike delivers measurements up to 4x faster than standard micrometers while maintaining exceptional accuracy with ±1 µm permissible error. Beyond speed and accuracy, the QuantuMike features a user-friendly design with an enhanced digital display, easy-to-use function buttons, and customizable settings. Its IP65 protection rating makes it ideal for use in manufacturing environments that demand high-precision results. New Digimatic S1 output capabilities allow for measurements to be exported to spreadsheets or data management systems.
Untitled-1-05-1
  • Utilizing a unique processing technology, the MDE QuantuMike features a wider thread pitch, enabling the spindle to move 2.0 mm per rotation - four-times faster than other micrometers.
  • The MDE QuantuMike has a maximum permissible error of just ±1 μm to ensure it meets the demands of high-precision workpieces.
  • An approach speed warning function helps prevent damage from excessive speed with a flashing display to alert users.
  • The calculation function automatically computes correction values for machine tools from measurement results. This eliminates the need for manual calculations to reduce human errors and help prevent processing defects.
  • Tolerance (GO/NG) icons on the LCD display for quick judgments. Upper and lower tolerance limits must be entered beforehand
  • The calibration period notification icon starts blinking at a set time before calibration is due (e.g. 1 week before the calibration date). If the deadline is exceeded, the entire screen starts blinking to notify the user.
The SJ-220 Surftetst is a portable, user-friendly surface roughness tester designed to be compact and easy to use with one hand, providing highly accurate results almost anywhere. The built-in battery lasts for up to 1,000 measurements without needing a charge, making the SJ-220 indispensable in the field or on the manufacturing floor.
41_3_178-741-11_202311_IM-3 1 (1)-1
The larger 2.8-inch color touchscreen back-lit display provides high visibility in all settings, even in dimly lit locations. The screen orientation is easy to change, and the new user interface helps make operations faster and easier. The touch screen supports flick and swipe operations as well, making it easy for anyone to perform measuring work. The SJ-220 meets a wide range of international standards, including the latest ISO 21920, and is capable of wireless data sharing and reporting with the optional U-WAVE-TIB and the free SJ-APP.
Divider-Visual-RA-220-Software
  • Compatible with new standard ISO 21920.
  • Built-in 2.8-inch color graphic, back-lit touchscreen display provides excellent readability, improved visibility and is easy-to-use in dark environments.
  • LCD display mode can be freely switched between portrait and landscape as well as left-hand or right-hand direction
  • On a full charge, it can be used to perform measurements approximately 1000 times.
  • Optional U-WAVE-TIB transmitter allows for wireless displaying of measurement results, setting measurement conditions, and bidirectional communication.
  • Dedicated “SJ-APP” for increased efficiency of measurement work
  • The display interface supports 25 interchangeable languages
indicators_generic-scaled
Mitutoyo ID-C and ID-F Digimatic Indicators provide incredible accuracy with higher resolutions down to 20 µ inch/0.5 µ m. The larger LCD screen can display various information in an easy-to-read manner and features an analog bar for convenient observations of subtle movements such as the approach to tolerance.
MITUTOYO IDC DIGITAL INDICATORS
  • The ID-C and ID-F ranges now include models with 20μinch / 0.5 μm resolution. The units are also capable of resolution switching. **Except for the ID-C 0.01 mm resolution model.
  • The LCD displays an icon to notify the user when the set calibration time approaches. This facilitates the proper precision management of ID-C/ID-F.
  • The units have large screens that can display various information in an easy-to-read manner. They also have an analog bar for observing the approach to tolerance.
  • The IDF Indicator Series features a backlit display that shifts from green to red when out of tolerance.
THESE SPECIAL DEALS WON'T LAST FOREVER!
These special deals won’t last forever! Be sure to download the 2026 Mitutoyo Spring Promotion brochure to save on popular Mitutoyo tools and instruments including the featured products above along with data management solutions, calipers, micrometers, linear encoders, indicators, height gages, microscopes and hardness testers before June 30th, 2026, when the Spring Promotion ends!
Are you ready to SAVE?
