Skip to content
logo (3)
Shaft Measurement Made Simple
The Mitutoyo SV‑M3000CNC Shaft Measurement Solution is a turnkey system that automates surface roughness, contour, and waviness measurement across a wide range of shaft‑type parts, including camshafts, crankshafts, e‑mobility rotor shafts, transmission shafts, and ball screws. A flexible shaft fixture speeds setup, while X/Y/Z motion delivers traverse speeds up to 200 mm/s to shorten inspection cycles. FormTracePak and the Universal Interface automate from measurement to raw data, plots, PDF reports, and AQDEF-compliant SPC output, from program selection to data output, the workflow is streamlined end‑to‑end for high-speed, automated results.
Why Choose the SV-M3000CNC Shaft Measurement Solution?
End-to-end on one screen: From part ID to program execution to inspection result output with no app switching
High throughput from end-to-end automation and rapid axis positioning
Generate repeatable, audit-ready reports
Measure complex shaft features with full CNC, multi-axis control and a flexible shaft fixture, one setup for many geometries
SV M3000CNC Overview 1-2-1
Larger 2.8-inch Touchscreen
New HOME Key
Increased Efficiency
Tailored for Shafts
Our Shaft Measurement System utilizes an SV-M3000CNC gage at its core, providing speed, accuracy, and repeatability. A flexible fixturing system is added for simple lading and reduced operator influence.
undefined
SV M3000CNC Overview 1 Zoomed in
Flexible Shaft Fixture
The flexible shaft fixture is designed to accommodate various shafts, including camshafts, crankshafts, ball screws, and more.
Form Stylus Move
Maximized Inspection Speed
The sturdy structure of the X, Y, and Z axes allows traverse speeds of up to 7.78”/s (200 mm/sec). This high-speed positioning helps reduce overall cycle time.
Software SMSscreen-1
Automated Data
Mitutoyo FormTracePak" software generates inspection reports and plots and saves raw data. The UI (Universal Interface) allows for integration of barcode scanning, selection of parts and inspection program, and can generate SPC outputs in various formats, including AQDEF.
Example Applications
Shaft_meas-02
Camshaft Surface Finish
Measurement location example
  • Journal
  • Base Circle and Lobe
  • Others | Front face, rear face, thrust face, etc.
Shaft_meas-01
Threaded Shaft
  • Thread pitch
  • Other | surface finish
Shaft_meas-03
Crankshaft Surface Finish & Waviness
  • Main Journal
  • Pin
  • Thrust Face
Learn more about this Solution
